procharged 408ci lq9
Old 03-23-2014, 06:28 PM
t0mmyb0y77's Avatar
Default procharged 408ci lq9
I have a texas speed lq9 408 ci, with callies crank, callies H-beam rods, wisco -20cc pistons. 247 Precision race heads 2.120 intake and 1.600 exhaust. Arp head studs, arp crank and rods. Ls6 intake for now. Dyno max long tubes. D1 procharger with a 330 pulley. Brute speed procharger bracket tensioner. Custom comp cam. Melling high pressure oil pump. Ford 80lbs fuel injectors. And a tranzilla magnum t56 transmission rated at 1000 ft lbs torque. Ram 10.5 dual disk clutch rated at 1000 ftlbs torque. Also getting the brute speed single intercooler with wastegate to support the 1000hp. Someone wanted me to post my build on here. So here it is.
Old 03-23-2014, 06:44 PM
ramairetransam's Avatar
im here and in for pics man . Cant wait to see the number on this beast .
Old 03-23-2014, 06:45 PM
t0mmyb0y77's Avatar
Couldnt post pics on this thread but I made a album on my profile on here
Old 03-23-2014, 06:52 PM
t0mmyb0y77's Avatar
Here is a few
Attached Thumbnails procharged 408ci lq9-999801_10151787244586436_1786590309_n.jpg   procharged 408ci lq9-1518598_10151787244726436_662382870_n.jpg   procharged 408ci lq9-1527061_10151780154421436_1426094457_n.jpg
Old 03-23-2014, 06:55 PM
t0mmyb0y77's Avatar
Here is the spec sheets
Attached Thumbnails procharged 408ci lq9-20140225_182711.jpg   procharged 408ci lq9-20140225_182506.jpg   procharged 408ci lq9-20140225_182733.jpg
Old 03-24-2014, 10:31 PM
I8UR4RD's Avatar
in for results!
Old 03-25-2014, 02:07 AM
WS6ICK2k's Avatar
subscribed!!!
Old 03-26-2014, 08:58 PM
95-1LE-Z28's Avatar
Here you go....
Old 03-26-2014, 09:13 PM
conan's Avatar
Looking good in for the end...
Old 03-27-2014, 07:13 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
My guess is 765/680, but it all depends on the tune and how aggressive you get with timing and fueling.
Old 03-27-2014, 09:02 PM
sway99bird's Avatar
Badass my turd goes into the shop Saturday to get the D1 installed !
Old 05-23-2014, 01:03 PM
95-1LE-Z28's Avatar
Any update on this build?
Old 05-24-2014, 11:46 AM
soundengineer's Avatar
that is about where I would guess....
its about all a D1 is good for...
Old 05-25-2014, 07:02 AM
Firehawk441's Avatar
Don't bet on that.
Old 05-25-2014, 08:27 AM
Originally Posted by Firehawk441
Don't bet on that.
a few people are spinning the living daylights out of them on well built combo, making it into the 800's....
but thats really pushing it...
1300~14000 CFM....cant do much more than that.
if you see more... you have a Happy dyno
Old 05-25-2014, 08:38 AM
I broke 800whp on a Dyno jet and 700whp on a mustang Dyno at 6000 RPM. 7.65/3.55 pulley combo= 53011 rpm
Old 05-25-2014, 08:41 AM
Like I said above........
Old 05-25-2014, 04:44 PM
UNDER PRESSURE MOD
Well, I made 762/688 with a combo that isn't optimized at all. I don't have enough exhaust, I have a NA cam in it, and my tune was ultra conservative at 10.8 afr, 15 degrees of timing. With a blower cam, better exhaust, and getting the tune straightened out, 825-850 isn't out of the question. I hit that 762 at 6,000 rpm and had boost leaks that dropped my boost psi past that.
Either way, a D1 on an optimized setup will make 775-850 depending on dyno.
Old 05-26-2014, 12:39 AM
8 Second Truck Club
Blown06's Avatar
I gotta agree
Quick Reply: procharged 408ci lq9
