coverter help 300 shot
just put a glide in my 99 trans am 408 stroker 1.76 glide pro brake, 4.10 gear 9" rearend, steve Johnson black widow plate pilled for 300hp leaving on all on it off brake converter is ptc nitrous converter is stall to 4000 on brake... this converter was in my th400 then I went to glide just was going to try it in.. with th400 if went 1.25 60ft 5.69 1/8th now went to glide it went 1.30 60ft 5.78@ 120mph with electric shifter set at 6900rpm it just doesn't leave as hard as th400 . i know the first gear is different... do you think I need a 2 step and set it 3200-3500 it will help? or just sent it to ptc to get it restalled also trans has hydraulic fluid it in....
What rpm does the converter go to on the launch and what rpm drop do you have on the shift? I sent my converter to PTC to have it tightened 800 rpms. Got it back took the launch from 70% to 50% and it stood up and broke a limiting chain. After the broken parts are fixed I'm excited to get it back out.
haven't look at the 1st to 2nd shift drop thats what I got to see now....i know without 2-step on brake it stall to 4000... I set 2 step at 3500 only 60ft was 1.32 1.34 then set at 3800 It went to a 1.24. 1.27 got new slicks now 1.30,1.34 think it still to tight not sure
So the converter stalled at 4000 before and now at 3800? I was thinking it needed to be loosened. What does the rpm jump to on the nitrous and what do you shift at and what does it drop to?
yea its a 408 stroker ported 5.3 heads comp cams nitrous cam 1.76 powerglide PTC nitrous converter 4.10 gear induction solution black widow plate pilled for 300 off the brake super vic intake ported..hyd roller lifters ,4150 fast tb 1 7/8 long tube to 3" to MF mufflers 3300lb with me in it 28x10.5-15 stiff side wall... its nothing really special can't wait to get 235cc afr heads go solid roller and get a 2" kooks header electric water pump and a vac pump and more nitrous
