Water pump question
Water pump question
There is a sleeve that goes over the water pump drive shaft, does it matter which way it goes? I slid it off and didn't pay attention,
Most water pumps and also the felpro timing cover gasket set come with 2 o-rings for the water pump drive coupler. The o-rings fit in the groove begind the spline section of the drives on the engine and water pump. In a pinch you can measure the O.D. of the drive groove and the I.D. of the unsplined part of the coupling and get a 0-ring that is alittle bigger than the difference of the two measurements. The dealer could probably get the o-rings if you can't find any. I've got the o-ring dimensions at home, I could post them up later.
http://www.rockauto.com/catalog/more...277&cc=1251942
Found another thread that somebody said the o-rings are felpro p/n 407. I can't confirm this right now though.
The o-rings are what keep the splines clean. Grease in and dirt out. #156 in the pic link I gave in post #3. They go in a groove near the end of each splined shaft (came from the factory that way). They often get real flat or crumble away.
From my post #9, Part Numbers and dimensions for WP drive coupling o-rings if you don't want to use GM parts for whatever reason.
Felpro o-rings as listed on the contents of the timing cover gasket set TCS 45953. 2 ea. p/n 407. Looks like 50 cents ea at most auto parts stores.
I used Aircraft o-rings, p/n M83248/1-012. .375 id, .500 od, .062 wall.
Available from many places, below is just a example:
http://www.oringsusa.com/catalog/pro...ts_id=66008536
Gotta pull it back apart tomorrow, just realized i for got to put some sealant on the bolts, what a dumbazz move WTF luckily all I did was mount up the pump and nothing else, gotta love trying to become a do it yourselfer, kept the opti dry for the most part, hope I didn't screw that up
Village Troll
You mean the two bottom w/p bolts? You don't need to pull anything apart if that's the case. Just take one bolt out at a time, put sealant on threads and torque to spec. Two bottom bolts are the only ones that need sealant.
ya, well I pulled it back off to start from scratch, of course one of the gaskets ripped do now im f'ed, next time im taking it in
Don't sweat it. Gaskets only cost a couple dollars for the pair. Think of how much you're saving doing it yourself vs. taking it to a shop. Everyone has to start learning somewhere.
