need Nitrous Outlet fittings for the plate
Old 04-21-2014, 01:54 PM
dsadsdaiouser's Avatar
Default need Nitrous Outlet fittings for the plate
We have a LS1 78mm plate kit from Nitrous Outlet. Does anyone have a couple of the fittings that screw into the plate and then hold the jets? I stripped one at the tuners on Friday and when I called Nitrous Outlet today to order a few they're out of stock for 31 days. We're going to try to get to Super Chevy at the Motorplex next month and would like to run the True Street class but can't go if we don't find these fittings.
I appreciate it.
Scott
Old 04-22-2014, 09:31 AM
bmeyer40's Avatar
http://inductionsolutions.com/shop/a...t-jet-fitting/
Old 04-22-2014, 09:51 AM
brandon@nitrousoutlet's Avatar
The plate fittings we use are actually a 5/16-24 X 3AN. Scott, you'll have to re-tap the plate to use the fittings above.
I sent you a PM btw.
Old 04-22-2014, 10:14 AM
Thanks Brandon! I'll give you a call this afternoon on my way home from work. I'll also need the hard lines from both solenoids to the plate. I appreciate it and thanks again for the help Friday when we were on the dyno!
Scott
Quick Reply: need Nitrous Outlet fittings for the plate
