Weird Compression test results....
When I previously tested my engine all of the cylinders were between 225-235psi. This time when I did the test the results were 80-90psi. I had all of the plugs out, injectors unhooked, and cranking 4-5 times. What could be the difference?
Phillip
Phillip
