aquamist hfs-3 questions
i have not dealt with a water meth injection system other than on gran nationals and this aqua mist system is quite different.
my questions start with the harness that goes to the injectors. the instructions only tell me where three of the wires go (injector positive, ground signal, and maf) where do the other 5 or 6 wires in this harness go? also I'm have problems with the jet flow chart, I'm running 15 psi boost on a ls3 should be right around 900 hp
thanks in advance
thanks in advance
looked a little further, they had that particular harness split up in the instructions. now all i need to know is for sure that the injector ground signal goes to pin 36 with is inj 1 and thats the correct injector signal
