10 Bolt Problem?
Old 05-07-2014, 08:21 AM
cyberkill's Avatar
Default 10 Bolt Problem?
Last night I was in the process of removing the diff/carrier in order to install a 4.10. As I took it out, I noticed it was in 2 pieces! Surprisingly, I've never had issues with vibrations anywhere within 0-120 mph. The only thing was a weird sound whenever I would powerslide left (but not right).
Question: What exactly is the problem with the 10 bolt? Is there some problem with the design of the parts (ring, pinion, axles, Torsen centerpiece)? Or is it a problem that the materials for the parts are weak? OR is it actually a problem/weakness with the housing itself?
Oh, and when you say "The 10 Bolt is weak!" - is my picture an example of that? I don't have any metal pieces flying around or anything. The inside of the housing is clean, and the ring gear is clean too. Haven't taken out the pinion to really check yet, but I don't see large pieces inside the housing or on the magnet.
Old 05-07-2014, 09:37 AM
high n dry's Avatar
Omg!!!!
Old 05-07-2014, 10:08 AM
guppymech's Avatar
I've seen posts of that happening before. The problem with the 10 bolt is everything is just too small, I've read that the design originates with the Chevy Monza from the '70s. Sorry the cost of your project just doubled.
In your sig, you ran slower with your cutout open??
Old 05-07-2014, 11:19 AM
cyberkill's Avatar
Well, a 9" is definitely in the future, but not right now. I just ebay'd a used Torsen carrier just to get through the summer (and free up my garage!). I don't track it all that often, but I don't even have any of my Eagle F1 GS D3 tires anymore, so probably can't hook anyway on these crappy all seasons.
Oh, and yeah, with the cutout open I did run slower. That was before the tune though, and they tuned it with it open (because it's now stuck open, lol!). Haven't been to the track since the tune.
Old 05-07-2014, 12:02 PM
FirstYrLS1Z's Avatar
LS1Tech 20 Year Member
that cracked end plate on the torsen carrier occurs. If you search for 'catastrophic' in this forum,you'll see similar breaks for the torsen.
Old 05-14-2014, 04:31 AM
RockinWs6's Avatar
Axle was holding it in place.
Old 05-14-2014, 05:53 PM
JOHNNY59's Avatar
I have a torsen 10 bolt carrier for sale if still needed.
Quick Reply: 10 Bolt Problem?
