tuners:please check my diablo live data
Old 05-17-2004, 02:30 AM
skippytheloon's Avatar
Default tuners:please check my diablo live data
I recently installed a 160 stat and upped pe .05 and spark 2.00deg...but it should have had time to adjust by now.
Please, please take a look and give me any suggestions you may have!!!
current settings:
engine temp 183*
fuel (PE) +.59%
spark +4.00
reading at WOT:
LTFT1 .78
LTFT2 0
O2#1 915
O2#2 885
O2#3 915
O2#4 885
KR is always zero
Spark is 22* at idle and 35*-45* at partial to 99* throttle...but goes down to 28.4 when I hit WOT???? By my butt-o-meter, the car doesn't slow down any even though the spark dips to 28.4 at WOT and stays there.
What's going on,
Kyle
Old 05-17-2004, 10:37 AM
ataylors's Avatar
well not sure what your asking exaclty, it is normal for part throttle timing to be higher than WOT. You also might want to lower your fan temps a bit to take advantage of your 160 stat.
Old 05-17-2004, 12:00 PM
yea, that was the major part of it. I also just wanted to throw the info in with it to show everything else is around normal(barely rich I believe).
1. Why is my spark so low at WOT, I thought from the factory you should have about 29* of timing?
2. I want LTFT's in the slight negatives, right? how do I get them there and why is one higher?
Old 05-17-2004, 12:45 PM
Moderator
jimmyblue's Avatar
Stock tune is much lower than that on my '02. I had
to push the Predator tune to +10% spark to see 30
degrees. This all looks like pretty normal numbers,
you can keep jacking the spark forward until you
see KR and then back off a couple of percent for
warm air and bad gas, and stand pat. If you put a
bit more PE you would likely lose that last bit of
positive trimming though that would also make the
WOT O2s fatter and maybe make it feel a little
soggier around town. Just have to try and see
what gives you the best result, there. With more
PE you will be able to stand more spark.
Old 05-17-2004, 01:40 PM
I was hoping for maybe a +2 for that or this type of answer, but I guess your right. Shucks, I guess I just have to race it around some more
BTW I just came across emarkay's website from another thread, it's pretty funny if you haven't seen it before. Very creative just click on the "unique mods" link.
http://www.geocities.com/wastespace/
Old 05-17-2004, 01:50 PM
Wait, one more question if you don't mind:
How come my O2's are showing to be slightly on the rich side, while my LTFT's are showing me to be slightly lean? Like, if I richened my PE in order to get -4LTFT...wouldn't my O2 be showing me as pig rich
