View Poll Results: WhichBOV/ByPass loudest at all times @8-12lbs????
ProCharger-. PROFLO-BULLET
0
0%
ProCharger-. BigRed
3
18.75%
-Vortech.- Mondo
0
0%
-Turbosmart.- BIg Bubba
1
6.25%
-Tial 50
10
62.50%
-JGS 50 or 60
2
12.50%
-Jodar 50mm
0
0%
Voters: 16. You may not vote on this poll
BOV / BY-PASS opinions which one?
Which BOV/BY-PASS (open) for ProCharged application not planning on going over 12-14lbs. (& Maybe why this or that one) I Want it to be as loud as possible at all times (at idle & high RPM shifts,yes I would love it to sound like a "street sweeper")
-ProCharger-. PROFLO-BULLET , BigRed Race
-Vortech.- Mondo
-Turbosmart.- BIg Bubba,
-Tial 50
-JGS 50 or 60
-Jodar 50mm
I've heard & read some are not open much at idle so I want to avoid those, don't want to deal with surge. + I want it as loud as possible at all times.
So any one with knowledge/experience with any of these with a low-mid level boost (8-12lbs) S/C setup please help me out here. I know what the BigRed sounds like with a F-1 at 17lbs but thats not what im dealing with on this Vette. I'm leaning toward the BigRed,PROFLO-BULLET or Tial. ???????
Thanks for your time & input
-Vortech.- Mondo
-Tial 50
-JGS 50 or 60
-Jodar 50mm
VOTE if you have any input!!!
Please vote anyway if you don't want to post.
Oh if you vote on the poll plz post what # also so this thread doesn't disappear to fast.
post 1. for ProCharger-. PROFLO-BULLET
post 2. for ProCharger-. BigRed
post 3. for Vortech.- Mondo
post 4. for Turbosmart.- BIg Bubba
post 5. for Tial 50
post 6. for JGS 50 or 60
post 7. for Jodar 50mm
THANKS again for your time & input.
post 5. for Tial 50
BOV or By Pass Valve
I like Tial, going to be running one on my LS2/Buick T type , with ECS Paxton Novi 2000 blower system, They look the nicest,
My friend has the big red Procharger one on his F1-C 2001 camaro , its ok but i like the look of the polished or Black Tial anyday
Im running the little Procharger swing arm By pass valves on my D1-sc procharged camaro , im running twins and have one munted off of each intercooler, to me this works best when running twins, There are the better black ones they cost about 125-150 each from what i remember,
each one is good for up to 10-12 PSI acording to procharger and at the time i called them and asked if running 15psi could i just add another one they said yes , mount it to the other intercooler, so i did and they work great.
Is the Tial open completely at idle & cruze like the Big-Red ? I can't get a strait answer on that. Thanks.
The 1st&2nd pics are the reg Pro-Flow, the 3rd is the Pro-Flo Bullet.
Bov
Im running twins also, By Procharger swing arm By pass are you takling about the "Butterfly Valve type" like the reg ProFlo Surge Valve? (not the PROFLO-BULLET) ? Im running 1 of the "reg Pro-Flow" now & it leaks boost & not loud enough.
The billet one you show looks pretty nice, how much was it and how much boost is one good for?
I have the regular swing arm ones, But mine are a little older, but they are Black and come apart in case you want to rebuild them or put a new diafram in, I dont remember seeing that much space between the blade and body while the butterfly is closed either, I run two of them and have a breather on each of them to preven any dirt from getting in etc,
Any one have experience W/the Bullet,Big-Red & or the Tial?
However, I don't personally have to be at WOT for it to close. It closes whenever the car is under a decent amount of load, maybe somewhere in the 50% throttle range. And it is fairly loud -- my car sounds like an angry street sweeper when not under load.
I believe they changed the spring colors though -- mine was the "pink" supercharger spring, which I think is now "green."
My Tial Q BOV (with the supercharger spring) is indeed open at idle & cruise.
