External turbo leak.
Old 05-25-2014, 08:06 PM
LM7Nova's Avatar
Default External turbo leak.
Twin ebay t3. Identical oil drains and feeds. Driver side has a leak on the exhaust side. leaking from the point were the center section meets the turbine housing. Its mounted level with the ground and drain is 10an. Should i just buy a rebuild kit? This is a freash install first time turbos have spun.
Quick Reply: External turbo leak.
