How much power am I leaving on the table using 1 3/4" headers?
Just a quick run down of the car first. 390 Iron block, massaged 317 heads, Fast 90/90, Brute Speed boost cam, D1sc with 3.7 pulley, 7.65 crank pulley (10-13lbs) 4L65, 3600 stall, 3.70 gears in a Fab 9". Puts almost 700hp/ 650tq down to the tires. I'm currently running pacesetter headers 1 3/4" and Magnaflow exhaust. Just wondering if there's something to be had with getting larger headers vs a pulley swap and tune? What's everyone running for headers right now?
i would think a pulley swap/tune would be much more beneficial than bigger headers. and also that magnaflow catback probably needs changed out along with headers when you decide to squeeze out some more power.a set of 1 7/8 or 2" along with duals or a single 3 1/2 or 4" would be quite a chunk of $ but a better exhaust setup will obviously help.
Not an apples to apples comparison, but last fall I finished my heads/cam stock bottom end car. Exhaust was: 1 3/4" Stainless works (2.5" collectors), catted y-pipe (2.5") thru the SLP Dual/Dual. Over the winter I swapped to 1 7/8" Kooks (old version, not revised 3" collectors) to a offroad x-pipe (3") dumped before the axle thru Borla XR1's.
Entire exhaust was changed, resulted in an average gain of 12-15 RWHP and 15rwtq across the board. I would get that exhaust opened up, larger headers, and get rid of the y-pipe.
Exactly my point. How much did that 15hp cost in $$$ ? And more than likely the gains were down to either removal of the cats, or the retune...or a bit of both ( assuming you did retune after )
After the change, the tuner was able to throw another degree of timing as well. Huge pick-up. 20+ rwtq peak and 20+ rwhp peak.
