SDCE Fan Setup, Opinions And Experience??
hey guys so my procharger fan finally took a dump and does not work anymore, i saw this fan setup from SDCE for $399 and wanted opinions on it from people that either are running it or know about it, car is a 2000 trans am with stock radiator location, Thanks!
do you have the stock fan shroud that came with the procharger setup ? if so add a 9" fan to it if you want two . Im running two fans on the stock procharger shroud.
Just know none of those are anti freeze so replace or drain them come winter. And be careful, some of those don't have the proper lubricants for your pump.
I had the procharger fan set up,recently did the vertical radiator to the car,was able to trim the main fan bracket to almost a perfect fit on the griffin radiator. Then I cut the top procharger bracket down to hold everything against the radiator. Im new here and not sure how to post pics. I have a ton of them and it works great! Anyone interested can text or call me for the pics or to let me know how to post them from a cell.thanks 405-371-8571.
ok guys, so turns out i have the older 2 piece fan shroud from procharger, so in order to add the extra 9" fan i would have to cut out where the bolts are that hold the shroud together.. so i just replaced the 16" fan for now and the cars running cool... until i find a solution to add the 9" to my shroud...
i have a procharger two piece shroud , if you care look for my post about adding a second fan . it has pics. i posted in someone else thread but their are pics of it .
When you install the 9" fan with the 4 BOLTS it will hold the shroud together.
This is what I did when I added a 7'' fan to my 2-piece Procharger fan shroud.
Bolted the 2 halves together... https://camaroversion20.shutterfly.com/277
Hole cut... https://camaroversion20.shutterfly.com/277#278
Cleaned up the edges and reassembled the two halves using the fan bolts to hold the shroud together... https://camaroversion20.shutterfly.com/277#280
