SDCE Fan Setup, Opinions And Experience??
Old Jun 25, 2014 | 11:13 AM
underpressureWs6's Avatar
Default SDCE Fan Setup, Opinions And Experience??
hey guys so my procharger fan finally took a dump and does not work anymore, i saw this fan setup from SDCE for $399 and wanted opinions on it from people that either are running it or know about it, car is a 2000 trans am with stock radiator location, Thanks!
Attached Thumbnails SDCE Fan Setup, Opinions And Experience??-img_6494.jpg   SDCE Fan Setup, Opinions And Experience??-img_6496.jpg   SDCE Fan Setup, Opinions And Experience??-img_6498.jpg   SDCE Fan Setup, Opinions And Experience??-dsc08321.jpg
Old Jun 25, 2014 | 11:21 AM
ramairetransam's Avatar
do you have the stock fan shroud that came with the procharger setup ? if so add a 9" fan to it if you want two . Im running two fans on the stock procharger shroud.
Old Jun 25, 2014 | 11:34 AM
i do have the procharger fan shroud, its still on the car, but with a dead fan. ill have to put a new fan that will replace the procharger fan and add the 9 inch one, im not sure if its worth the hassle modding it if im only saving a few bucks?
Old Jun 25, 2014 | 12:01 PM
its worth the hassle , the 9" fan was like 90 bucks and i dont know what the larger fan runs , maybe 150 if that .
Old Jun 26, 2014 | 01:20 PM
yeah i decided to just add a 9 inch spal to the procharger shroud, it comes out to less than what sdce wants for their setup
Old Jun 26, 2014 | 01:32 PM
do you know the part numbers for both spal fans??
Old Jun 26, 2014 | 09:12 PM
on top of the fans im definitely going to use either Redlines Water Wetter,Royal Purples Purple Ice, or Amsoils Coolant Boost in the coolant...
Old Jun 26, 2014 | 09:44 PM
Jesus Freak's Avatar
Just know none of those are anti freeze so replace or drain them come winter. And be careful, some of those don't have the proper lubricants for your pump.
Old Jun 27, 2014 | 07:59 PM
if my heat problem gets solved with the fan setup then i wont even bother using any of the coolant additives
Old Jun 27, 2014 | 08:50 PM
SmokedOutZ28's Avatar
Fwiw I am using the SDCE Fans and in the Chicago heat & humidity my engine temps never creep up over 190 while cruising... Never over 180 idling in the garage.
Old Jul 5, 2014 | 03:47 PM
n2000ta's Avatar
I had the procharger fan set up,recently did the vertical radiator to the car,was able to trim the main fan bracket to almost a perfect fit on the griffin radiator. Then I cut the top procharger bracket down to hold everything against the radiator. Im new here and not sure how to post pics. I have a ton of them and it works great! Anyone interested can text or call me for the pics or to let me know how to post them from a cell.thanks 405-371-8571.
Old Jul 10, 2014 | 10:12 PM
ok guys, so turns out i have the older 2 piece fan shroud from procharger, so in order to add the extra 9" fan i would have to cut out where the bolts are that hold the shroud together.. so i just replaced the 16" fan for now and the cars running cool... until i find a solution to add the 9" to my shroud...
Old Jul 11, 2014 | 07:40 AM
Slowhawk's Avatar
LS1Tech Sponsor
Drill another hole to hold the 2 piece together.Pretty simple.
Old Jul 11, 2014 | 10:06 AM
i have a procharger two piece shroud , if you care look for my post about adding a second fan . it has pics. i posted in someone else thread but their are pics of it .
Old Jul 12, 2014 | 07:29 PM
Firehawk441's Avatar
When you install the 9" fan with the 4 BOLTS it will hold the shroud together.
Old Jul 12, 2014 | 10:27 PM
conan's Avatar
What these 2 said ^^^
This is what I did when I added a 7'' fan to my 2-piece Procharger fan shroud.
Bolted the 2 halves together... https://camaroversion20.shutterfly.com/277
Hole cut... https://camaroversion20.shutterfly.com/277#278
Cleaned up the edges and reassembled the two halves using the fan bolts to hold the shroud together... https://camaroversion20.shutterfly.com/277#280
Old Jul 12, 2014 | 10:38 PM
i didn't think the four bolts would be enough support but now that i see people doing it and it works fine ill go ahead and do that, thanks!
