Nasty Performance fuel rails.. what am I not seeing??
So here I am trying to install my new rails onto the stock LS6 intake, but something just isn't 'right', or I'm just not seeing something perhaps. The brackets the rails come with are drilled with multiple holes, but I can't quite make sense of it or see how it attaches the rail to the manifold. Take a look:
So I see a hole with a recessed opening for the bracket to manifold, however the other drilled holes run in directions that I cannot use to bolt the rails down. Bottom line, what am I not seeing or doing wrong??
Did you buy these from Nasty or used elsewhere ?
IMO, you're either missing some mount pieces that go between the blocks and the rails, that's IF he redesigned the mounts; doubtful.
Or, most likely you've got the wrong rails.
Those mount blocks are correct, but it looks like you've got the wrong rails.
The rail should look like this:
