Cant lean car out after aeromotive boost ref reg install
Earlier this year I upped the boost on my car from 9psi to 11psi. The car then struggled to get to my commanded boost enrich afr of 11.5. So I installed an aeromotive boost ref fuel press reg. And now I cant get the car leaned back out. WOT AFR is stuck between 10.1-10.5
I tried setting the base fuel pressure at 58psi, 56psi, 53psi, 50psi still everytime wot afr is in the low 10s
I even tried changing my boost enrich afr to 12.0 and it still runs like 10.2afr?
Am I missing something?
Reg is on the fuel rail and uses the stock evap line for return.
School me on what I need to do with this injector constant. Is this in the "injector flow rate vs. manifold press (kpa)" table?
