52lb (8) Fuel Injectors with Connectors LSA LS9 ZL1 CTS-V
Category: Accessories
Price: $250
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Genuine Bosch High Impedance EV14 Injectors
These injectors flow 52 lbs/hr at 58 PSI ( 4 BAR ) and more at higher PSI.
Features:
Genuine, reliable Bosch Injectors
Excellent response characteristics
Robust Design
High Impedance
Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Spray Pattern: Aligned bent cone, (6 orifice)
Electrical Connector: USCAR (New-style V=EV6 / Oval / LS2)
Fitted with Viton upper and lower o-rings.
Static Flow Rate @ 58.0PSI (400kPa): 51.72 lb/hr = 6.52g/s = 544cc/min (+/-3%)
Overall Length: 50.3mm
Dimensions: 33.5mm o-ring seat to seat, 37.5mm o-ring centerline to centerline
Applications:
Direct fit for LS9 Applications!
Made for high pressure, harsh environment turbo & supercharged applications!
Come with connectors shown in picture!
Fitment may vary.
Injectors Used, 5000 miles.
Connectors New in Package.
250 shipped
