Why use solid motor mounts?
Old 08-08-2014, 01:23 PM
DrX
DrX's Avatar
Default Why use solid motor mounts?
What are the pros and cons of solid mounts? When are they necessary or an advantage? Are there alternatives?
When checking out the damage from my recent test n tune trip to the track I found that my almost new trans mount was torn. Do you think this is related to too much engine movement or due to the rear u-joint blowing out? Better the mount than the trans case. I'm running almost new GM motor mounts(made in China) that appear to be undamaged.
U-joint tore out at the end of this video:
Old 08-08-2014, 02:17 PM
Moderator
jimmyblue's Avatar
Can't say why other people think solids are a good idea.
I like my Prothane mounts just fine, split the difference
between the stock and solid as far as transmitting motor
shake to the cabin etc. but went in easy without changing
how the motor sits.
I'm not going to break poly mounts, so why would I want
steel? Just more NVH in anything less than a max-effort
setup, in my book.
Old 08-08-2014, 04:16 PM
DrX
DrX's Avatar
AFAIK there are no aftermarket mounts for LS trucks.
Quick Reply: Why use solid motor mounts?
