WOT - LTFT is ~+6??
WOT - LTFT is ~+6??
Hi Folks
MY 02 SS has stock MAF, LS6 cam, ported LS6 heads (11.2:1), 36# injectors, SLP Long tube headers and cats. Modified the IFR table achieving a LTFT of -0.8 at idle and partial throttle of -4.7 B1 & -3.6 B2.
Well I did a WOT and the LTFT is +5.6 B1 & +6.7 B2.
Everything I read indicated it should be 0. What should I adjust to get LTFT to be 0 or close??
Thanks
Bill
Thanks
Bill
Originally Posted by Billiumss
Your Ltrims look right for Part Throttle. How many miles did you give it to learn? 20-40 miles is about right to get a good idea of whats going on. Do you have a screen in your MAF?
The IFR table is the one you need to tweak...
Bill
Bill
The car has almost 100 miles on it and yes The MAF has a screen. If I tweaK the IFR table, what do I shot for? I was going for a part throttle of -4 which I think is close.
Bill
When you modify the IFR table you have to do the whole table. I did some logging on a few completely stock cars and found that the Ltrims are anywhere from 0 to -12 anywhere from idle to just normal crusing. They ALWAYS lock at "0" when you go WOT
I would multiply the whole table by 95%, the numbers will decrease in value. upload program and drive around for 20-30 miles.
By adjusting your IFR table, your WOT is going to be off, most likely you'll be really rich.
You also want to increase your COT by 5-10% since your running cats. Increase all values by 105-110%
Thanks I will give it a try - I appreciate the help.
Bill
