check engine light on- secondary air injector
Old 10-03-2014, 07:29 AM
z28catfish's Avatar
Default check engine light on- secondary air injector
My check engine light recently came on so I got it checked out at the local auto-store. the code came up for the secondary air injector. I realize this pumps air into the cats, right? How long could I go before I need to replace the secondary air injector? Should I even bother replacing it?
Old 10-03-2014, 07:33 AM
z28catfish's Avatar
Oops, forgot to say it was a 2002 z28
Old 10-03-2014, 09:48 AM
NW-99SS's Avatar
Not sure on your State emission requirements? If you need it to pass, that's the only reason I would replace it.
Old 10-03-2014, 10:11 AM
It's not mine! woo hoo!
demonspeed's Avatar
Yank that AIR system out
Old 10-03-2014, 10:59 PM
JDEP162's Avatar
i get that code once in a while and weekly get the 0416 bad air pump. i just clear with scangauge and keep driving. just been too lazy to yank air system.
Old 10-04-2014, 12:15 PM
z28catfish's Avatar
So I don't even need the damn thing? Might as well just take it out then. No use in extra weight I don't need.
Old 10-04-2014, 12:17 PM
z28catfish's Avatar
alright, thanks. Just wanted to make sure I wouldn't damage the catalytic converter
Old 10-06-2014, 03:33 PM
demonspeed's Avatar
Not unless you need it for emissions inspection where you live. You'll still get a CEL until you get it tuned, but it won't adversely affect anything.
Old 10-07-2014, 07:53 AM
z28catfish's Avatar
There's a couple guys around that do inspections that tend to look the other way on that kind of thing so I'll be good. That's an easy 10-15 lbs off, don't you think?
Quick Reply: check engine light on- secondary air injector
