2000 model 6.0 and 4l80 converter question
I have a 2000 model 2500 truck, 6.0 with 4l80 trans. Converter is starting to slip. Need to replace. I know the 2000 model 6.0 has the extended crank hub and converter must fit this. I'm told i can cut down the hub on the converter for newer models to fit. If i do this do i have to change the flex plate also? I was thinking that they are different too. Thanks
