just ordered zaino for 1st time
i just ordered zaino for the first time i ordered z-2, z-5,and z-6, it seems this is the most common combo, in what order should i use these in. any other info would be helpful, i have a few coats of nxt should i leave it on there and give it a good wash or what.
thanks
thanks
Wash it with Dawn FIRST, and get anything and everything NOT ZAINO off before you apply it. That will yield you the best results! Also, they have very detailed instructions for applying it on their website. I'm sure you're familiar with it, but it's www.zainobros.com Good luck, and post lots o' pics when you've completed your first coat or two! Do a before and after series or something.
Chop-Foo Director
Too bad dawn will not strip the NXT off your car, just like it won't strip Zaino off your car. You best best is to use a water/alcohol mix to clean the NXT.
Although I don't know why you would switch from one to the other, they both shine just as well as the other.
A 50/50 dilution of water and alcohol is common practice for removing residue from abrasives, polishes, etc. It won't harm anything and will take you down to bare paint. (Which is what you want, for the Zaino to bond to)
