parts parts parts
parts parts parts
Category: Accessories
Price: $54321
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Used
Engine: LS1/LS6, LT1/LT4, Small Block
LS Engine?: Fits LS Engine
ls6 springs locks seals retainers take offs "zero miles" from livernois cnc heads 125 shipped
LS1 main ARP studs 190 shipped(lost one nut was replaced 6 pt rest 12pt)
rear coil springs 50
1995 Camaro driver and pass door with 5k miles only when removed
1995 gray cloth door panels
1995 tan trans am door panels
t56 boot 75 not ripped
lt1 ceramic elbow SOLD
Aeromotive Fuel Filter uses -12 AN Female Inlet / -12 AN Female Outlet 12302 filter, stainless steel 100 micron filter,will come with 1-12 fitting 90 shipped
ls1 cross over not H 30
new 862 heads
317 heads
abs module
afco D/A nuts new 75 pair
4l60e crossmember 50
t56 cross member 75
monsoon amp 35
new slp mats front mats SOLD
slp rear mat SOLD
camaro 93-95 driver and pass gray cloth panels only 5k miles 125 pair
ls1 fuel "pump" removed when new oem not after market sold
camaro review mirror removed near new 30
transam firebird tan interior trim near rockers 40
convertible floor brace $25
LT1 Fuel lines hard 95 and plastic 25
door exterior seals. glass to paint seals dr and pass 30
antenna.
Chassis heat shields 10ea
Door hinges 25ea
93-97 fog lights parts misc price
head light bar holds lights 30
Steering u-joint plastic covers 10ea
Driver window parts misc price
T-top conversion parts misc price SEALS MISC PARTS
Convertible pump low miles 200
Convertible top arms 200 each
Windshield washer pump new 12
whitedriver and pass door only 5k miles 300 each
under dash plastic insulator above feet area 10
rear sway bar 30
air dam under car rk sports 25
tan pass rear 1/4 plastic tire cover area small issue 5
rear berger panel stock no eblems 65
t top receivers 12 ea
wiper motor assembly 50
lt1 evap can 10
driver 1/4 evap vent 10
evap plastic lines 10
rs body body clips 6 ea
cruise control control and cables 50
Interior Pieces
Spare tire wrench 8
Air bag modules 25ea
air bags 93-02
hvac controllers 25
speaker grills 10
ls1 front fuse box plastic holder, brand new condition. 25
2002 ls1 cluster very low miles like new 150
cluster 0-150 mph v8 from 1997
Engine:
ls1 engine part
upper air box removed when new 50
ls1/lt1heater core removed when new 40
lq4 intake,inject, rails
ls1 y pipe pipe like brand new 125
ls1 fuel pump used 100 miles like new oem SOLD
ls1 rocker arms used 75
ls6 water pump used 1 hour like new 145 oem
Fueling:
Gas tank straps
Misc hard and plastic lines
Braking:
V6 drive by wire pedals 1999
V6 brake pedal single 1999
Drive train and Misc.:
sway bar mounts upper 10
sway bar lower half's 10
rear spring isolator 20ea
stock lca 20ea
many misc lug nuts from 93-02
driver glass
gray cargo cover one pivot gone still very nice cover
lt1 head SOLD
lt1 intake 40
lt1 injectors 80 set SOLD
throttle body cable plastic cover SOLD
lt1 coil 15
lt1 head coolant tubing 25
lt1 brand new oil pan 50
lt1 valve covers 30
lt1 alt 70
2002 z28 pass air bags with est 100 miles
steering column support 10
abs module 3 channel 100
tan floor mats new set used set 40 ea
brake booster 40
brake master cylinder 50
wiper arms 35 ea
gage cluster 97 $85
gage cluster 2002 2k miles on it like new 150
tan trans am door panels 125 pr
t56 cross member 75 +ship
a4 cross memeber 50 + ship
2004 ls1-lq4 truck harness trans wire cut
new lq4-lq9 injectors $125
new 4.8 5.3 ls1 heads great for silverado or higher comp ls1 $350 pr
317 boost ls1 heads pair $250
1998-2002 front grill with plate mount like new $100
mini cooper rear wing in white $100
1993-2002 z28 exhaust tips with pipes $80
new complete lq4 lq9 intake rails injectors t.b gasket $325
ls1 cross over 30 3pc design
camaro review mirror removed near new 25
4l60e trans rear mount oem 20
1 rear drag bag with hose, no schrader valve
ADDED SOME MORE
4l60e chrome pan
lq4 flex plate
15677589 flexplate thick cast cover
lt1 intake manifold painted black brushed finish on rails 25k miles on it
ls1 ac condenser
vortec plastic engine cover
lq4 oil dip stick and tube
one back of 4 coil pack
one bank coil packs with heat sink
center bolt valve covers pair
ls1 rocker stands pair
lt4 engine intake new carbed version
ls1 oil cooler tubing and hoses, ends have been cut, still good for a custom set up
oil filler tube and cap
lq4 front cross over tube
camaro trans am spare tire hold down bolt and washer
lq4 windage tray full length
4l60e gear slector switch on side of trans
stock z28 exhaust tips and pipes to muffler, only 2k miles on them
silverado tahoe suv tow mirrors. was on 1999 Silverado, that style mirror 25
lq4 water pump 40
ls1 a4 shifter cable 25
lq4 flex plate 35
lq4 motor mounts 60
6.0 injectors oem used for 10 min 100
lq4 ac pump 50
silverado fuse block 80
silverado dbw intake rail map injectors 125
1998-2002 camaro trans tail 4l60e 75
FAST RPM KIT 100
lt1 Rear rotors 30 pair
lt1 intake 50
lt1 rubber intake elbow 48 not torn
ls1 a4 shifter 50 low miles
ls2 ls3 oil pan 250 shipped
lt4 valve covers
lt4 carb intake
lt4 block off timing cover
LS1TECH Sponsor
how much for the LT1 intake manifold shipped to 75154?
Lloyd Elliott
972-617-5671
nighttrain66@msn.com
Lloyd Elliott
972-617-5671
