pvc plastic tubes cracked
Old 01-16-2015, 08:52 PM
SilveradoLS187's Avatar
Default pvc plastic tubes cracked
When my LS1 5.7 was out of the donor Camaro I noticed that the hard plastic tubes for the PVC were cracked up pretty bad. I was wondering if I could just take rubber hose and replace them and buy a plastic t fitting and not have to buy the ridiculous expensive plastic lines. What have other people done on there's?
Old 01-16-2015, 09:51 PM
99Bluz28's Avatar
Yes you can, use a good oil/fuel line hose and re-use the driver side valve cover plastic fitting unless it's also busted. I'd also just skip the T or Y fitting and just cap off the passenger side rear port.
Old 01-17-2015, 07:08 AM
Save the manuals!
wssix99's Avatar
There are illustrated threads on this. Just make sure you search for PCV fix and not PVC.
Old 01-17-2015, 12:20 PM
Thanks, sorry about the typing mistake the auto spell messed me up .t Thanks for the help.
Old 01-17-2015, 09:09 PM
LS1121's Avatar
how about a PVC PCV, that was funny.
Old 01-18-2015, 10:02 AM
Save the manuals!
wssix99's Avatar
I get my acronyms reversed all the time and PCV isn't one that rolls off the tongue.
But... we WILL make up special site flair for the site member who can make a durable PVC PCV fix. (The scraps could be used for a street hockey goal. How cool would that be?)
Old 01-18-2015, 08:51 PM
I blocked off the one on the rear of the passenger side and just ran one to the back of the drivers side. I haven't driven it yet as I've had the dash out of the truck putting a speedometer in and also mounting the ECM and I need to clean up the rest of the wires.
Quick Reply: pvc plastic tubes cracked
