cam only LS1, injectors?
I am getting ready to install a tick sns 3 on my 02 ss. Stock 241 heads with new springs. Martin told me i should be good with stock 28.8 injectors, but i see so many cam only threads going both ways. Some guys are maxing the injectors, others aren't. I would hate to get to the dyno, and not have enough injector, and have to possibly pay to hit the dyno again. The stock pump is in great shape, so i have been looking for some 30 lb 3 bar injectors to keep from swapping the pump at the moment. The problem is, i can't find any! All i can find is 36+, and a 255 set-up is out of the budget at the moment. So are injectors, but if i need em i will get them. Any insight would be great! Thanks,
https://ls1tech.com/forums/fueling-i...-vs-stock.html
A Racetronix 340 specific for 99-02 F bodies will probably allow you to stay with the 02' injectors. The pump and hotwire kit is about the same money as a set of injectors. The 255 that is not F body specific sucks. If you do decide to get bigger injectors look for a set of LS2's or other stockers. The injector data is easy to get.
