how mcuh will ls6 intake throw off the air fuel?
how much will the ls6 intake throw off my air fuel ratio? ive got all the bolt ons and im jsut curious if i coudl richen up the car a little after the intake swap until i hit the dyno. what do you all see usually?
Moderator
The intake itself will make little or no difference.
It's pipe. However, deleting EGR will affect your
low/cruise cylinder charge and make you able to
tolerate less spark advance than before (but
have more power in these part-throttle areas).
Expect some part-throttle pinging, may be less
a fueling issue (probably learnable) than a too-
much-spark-for-cylinder-charge issue. Have to
see, might need spark table tuning (or might
get by).
get by).
