Looking for someone around Duluth, GA to do CAM install
I know some people on this forum do these installs alot and figured I would check here first. This is for my 99 Z28 M6. It is pretty stock, I have only added Coated Longtubes, Borla Catback, Offroad Y, MAF Translator, and a Lid.
I will drive a pretty reasonable distance from my house to do the install or if you needed, I have a normal garage that has most of the tools needed to do the install, air compressor,some air tools,etc.. If anyone is interested just pm or reply back to this thread and let me know when you are available and your price and I will get right back with you. I am on the fence as to which cam to install but called Thunder today about the T-Rex Kit with the 921's as this car is not driven alot. It is mainly for fun and stays garaged most of it's life. I also need someone to tune it as well once the install is done so if anyone is interested I can buy the HP Tuners setup or if you have it or LS1 Edit (Multi-car) I will pay for your time.
Thanks for anyones help,
James
James
Thanks for the info, I just tried PM'ing that username and it said it wasn't valid. I did a search on the usernames thinking it might have been one off but couldn't find any that where similar. Do you think he may have changed his username?
Thanks,
James
Thanks,
James
You are spelling it wrong ( or not spacing would be better stated.)
Here
https://ls1tech.com/forums/member.php?u=2320
Here
