What all would you need to get, to make the electronic/induction system on the LS1???
OK, Say I got a longblock, what would I need to complete it??
I know:
Computer
Sensors
MAF
Intake
The reason I am asking is because I may want to start off with an LS1 block and build up, beings I dont have the money to but one off the bat...
Thanks
I know:
Computer
Sensors
MAF
Intake
Thanks
JustFloorIt, I'm doing the same thing. Its taken me about 6 months to get (almost) everything off of ebay. Here is what I have purchased so far (You wont need the heads as I did, since you have the long block):
I'm still looking at spending another grand or more for the following:
Long story short, it may not be any cheaper, but if you can only spend bits at a time and arent in too much of a hurry, you can do it.
Hope this helps,
ROCNDAV
- LS1 Shortblock $326.01
- LS1 Intake manifold $41.01
- LS1 Allen bolt kit $51.00
- LS1 Head Bolt Kit $59.00
- Chevy LS1 High performance Book $15.95
- OEM Air lid $10.50
- Crank Pulley & Belt $13.01
- LS1 Waterpump $40.00
- Center-bolt valve covers and coils $50.00
- LS1 Cam & Pushrods $20.00
- LS1 PCM & Harness $175.00
- LS1 Heads
- LS1 lifter & Rocker arm Assy $71.00
- LS1 Oil Pump $36.00
- LS1 Timing Cover $31.00
- LS1 Air Pump $27.89
- LS1 Catalytic Converters & Rear O2 sensors $30.00
- LS1 Fuel Pump & Sender $45.00
- Dura Bond Cam Bearings $16.49
- LS1 Cruise Control $1.00
- LS1 Air lid $1.00
- LS1 O2 Sensors (Pre Cat) $20.00
- LS1 MAF sensor $5.00
- K&N Filter $22.02
- LS1 Cam Gear $5.00
- LS1 powesteering cooler $12.59
- LS1 Valve Springs $20.00
- Engine Brackets (Alt/AC/pulleys) $50.00
- Oil Pan $52.01
- Radiator
- Air Lid Base
- Filter housing
- T-56
- Slave Cyl
- Cooling Fans
- Fuel Rail
- Fuel Injectors
- Retainers
- keepers
- Driveshaft
- Alternator
- Starter
- A/C Compressor
- throttle body
Hope this helps,
ROCNDAV
