Solid roller cam in C5R block...
Old 06-14-2004, 10:17 PM
BurnOut's Avatar
Default Solid roller cam in C5R block...
What needs to happen?? I know that the lifter bores need to be bushed in a stock block when converting to SR, but I have heard that the C5R block doesn't require it... is this correct??
Obviously, also the lifters themselves (ya think??), adjustable rockers, and valve springs to match, but is there anything else??
Old 06-14-2004, 10:36 PM
I can shift faster than you.
Jason99T/A's Avatar
The C5R blocks most definitely need to have the lifter bores bushed when going to a solid roller.
Jason
Old 06-14-2004, 10:57 PM
BurnOut's Avatar
Jason- that's what I needed to know... thanks!!
