Tr 224 cam 114 LSA question
This car is my daily driver so 20k will go by pretty fast. This is one of the reasons holding me back. Anyone have another story to tell about mileage vs springs with this cam?
Or should i go with the 02+ ls6 cam and springs and not have to worry about swapping out the springs.
i like my asa cam which dont require frequent spring changes but might be a little more than you want it has 226 236 duration lift is .525 .525. springs are really not an issue with it. its a good 390hp cam on stock heads bolton car makes awesome torque too!!!
Its a baby cam for sure these days with ls1edit. The car runs like a stock motor car right from GM. The few hundred dollars needed every 20 to 25 k miles to replace the valve springs is certainly a small price to pay for the performance benefit.
This is just my opinion so take it with a grain of salt.
Great mod for a daily driver .
I had TTP performance in Saddlebrook NJ do the install and its seamless except for all the added power.
JB
Will this 226 236 cam pass cali smog?
isnt it the smaller the lift the less hp you gain from the cam?
lift is not all that matters on cam. duration,lsa,and other factors come into play. the asa cam will not pass cali smog. if i were you i would call futral motorsports or texas speed both are sponsers on the right-------------- tell them what your looking for and they both will recommend you a cam. both are very helpful companies. good luck!
