Drag Racing Tech - Correct burnout?
Do u guys start in 1st and shift into 2nd when doing a burnout with an automatic? Or just leave it in 3rd and do the burn out.
JS
ScWhite 02 Z
04-02-2002, 02:31 PM
i leave in 1st go to raughammer's web site and he has a bunch of stuff like that to help you out
http://xs-fx.com/raughammer/ <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Pro Stock John
04-02-2002, 02:42 PM
(On skinnies), I drive thru the water, do a one spin of the tires, pull to the front of the water.
I have the gear selecter in 2nd, and I wack it and let it shift into second, I hold that for a bit, and then I shift into 3rd, and then i roll out...
I don't like leaving it in 3rd because it will shift into 3rd before the tires are even hot.
GeorgeC
04-02-2002, 03:04 PM
I drive through the water to just the wet edge of the burnout box. Press the brake pedal, hit the linelock button, and gently give it some throttle. Quickly shift into 2nd, then 3rd, hit it and let go of the linelock and roll out of the water with the tires smoking...
GeorgeC
04-02-2002, 09:16 PM
...And as a special "I'm bored as Hell bonus" here's a short video of one of my first burnouts w/the linelock hooked up. I wasn't expecting the tires to start turning over quite so easily <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
http://home.attbi.com/~gcoffey1/georgec_burnout.mpg
Magnus
04-03-2002, 10:06 AM
Even with skinnies I drive AROUND the water box.
Back into the center.. quick spin..
Roll toward the front edge, gear selector in 2.. and burnout.
Then I carry it foward 5-10 ft.
2000 Camaro SS
04-03-2002, 10:20 AM
I do the line lock thing but I just start in third and stay there. Am I not getting the burn I would other wise if I were to go to 2nd and 3rd?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
