GM top end cleaner
GM top end cleaner
I ran the GM top end cleaner through my PCV line tonight. It sucked it all up in no time and I am going to let it sit over night. After putting the cleaner in I started thinking that maybe I should use 2 bottles. So tomorrow morning is it OK to drive the car ~20 miles to work? I figure this will burn the cleaner off, then I can pick up another bottle of it from the dealer near work. Run it into the car at lunch time and then let it sit in the car for 4 hours or so. Drive back home to brun off the second bottle, and then change the oil when I get home.
Is it OK to drive the car for ~40 miles before changing the oil after using the top end cleaner? or will this cause damage to the engine?
thanks
thanks
