Still having problem W/ EFILive cutting out on GTO
Old 06-21-2004, 05:32 PM
jformato's Avatar
Default Still having problem W/ EFILive cutting out on GTO
I have never had any problems with this scanner but with a 04 GTO the scanner quits logging (freezes) after 30% throttle and then returns after the throttle is back down. Any help is appreciated.
It is Version 6. we have played around with the baud rate and pids and different packets but to no avail.
Thank you In advance.
Jeremy
Old 06-21-2004, 06:26 PM
Moderator
jimmyblue's Avatar
Have you tried the source, the folks at www.efilive.com?
