Comp "R"s and shims WTF
Ok i'm getting ready to install my new heads,LSX, H/S roller rockers, plus more and my ? is should i shim my H/S RR's for these comp r lifters or sell them and get a adjustable RR's. BTW my new heads have Comp 977 springs. Please help Thanks Shawn
I have seen this debated many times on here before. The guys who shim them are hit n miss but the guys with adjustables have no problems whatsoever. These lifters are designed to work with an adjustable rocker.
I am running comp R lifters with crane 1.7 adjustables. They were easy to adjust and since its a hydraulic there is no need to adjust them again.
I got mine from VINCI they call them "Accelerated lift" and say they are a 1.79 ratio. At full lift they are 1.7 Here is a link http://www.vincihighperformance.com/
Give them a call they are great to do bussiness with.
Brad
Brad
Originally Posted by Nasty N8
There is absolutly no need for adjustables you just need to get the preload correct for the Comp R`s. They are still hydrolic and require 1/4 to 3/4 turn preload.
Nate
Nate
Nate your information is incorrect. The R series lifter requires .002"-.004" of preload. These guidlines are here for a reason...use them. Comp also now offers pushrods for the LS-1's in .025" increments for these problems
7794-16 5/16" 7.325"
7795-16 5/16" 7.375"
7796-16 5/16" 7.425"
7797-16 5/16" 7.475"
