Unplugging front 02 sensors...open loop?
Old 06-22-2004, 06:22 PM
Fireball's Avatar
Default Unplugging front 02 sensors...open loop?
will unplugging/removing the front 2 02 sensors force the car into open loop?
I want to retain the maf but go into open loop tuning...is this all I need to do
Old 06-22-2004, 06:41 PM
Adkoonerstrator
XLR8NSS's Avatar
I think all you need to do is go in to the "Closed Loop Enable Temp" in the fueling section of LS1edit and raise the coolant temps up that the car goes into closed loop at.
Old 06-22-2004, 06:47 PM
Moderator
jimmyblue's Avatar
That's a great suggestion... simple. And that way you get
to see what the sensor says about things.
