will these fit
they are the new invis-o-wheel.j/k...here they are
http://cgi.ebay.com/ebaymotors/ws/eB...category=43958
i know on the sticky it says the bigger offset, the more in the wheels are. will these wheels look ok with that big of an offset?? where else can i buy some zo6 wheels from that will have a smaller offset?
As Todd said they will fit. They will look fine. The OEM offset on Camaro is 50 mm, so I personally like offsets that are smaller than stock to get a more "aggressive" look.
I have talked a lot about the Z06 wheels in the past, try a search and see if that info helps.
911...this is generally what you see on most of the cars here. 56 offset is the most common. If you are on stock Z wheels now...these will look more agressive and both go more inside, and more outside as well. If your on 17s...it will look pretty similar, cept maybe you can get a bit more beefy with the tire. We also sell these wheels.
