G5X3 cam and Vacuum???
Will I need a vacuum booster when I install this cam? I have the 114 LSA one and someone mention to me that I will not have enough vacuum for my brakes because of the size and duration of this cam???
Originally Posted by Ravenous T\A
Cool, good news, what kind of power did you put down with this cam? and did you have this cam before the heads and if so what numbers then?
I did Heads n cam at the same time. Its a 2000 z28 M6. Mods are g5x3,comp R lifters, Vinci Rockers(1.7), Patriot ls6 style heads(59cc chamber) ls6 intake w/28lb injectors, Lid/CAI, stock descreened MAF, TSP ported TB, Pacesetter long tubes, duals 3" into x pipe 2.5" out into Spintech Pro Shootout Mufflers, Spec StgIII , Nine ince w/4.33s. Tuned thru the mail by Chris Robinson. Not sure of the race weight but I had only removed the front sway bar and the spare/jack so I am guessing 3500 to 3600 lbs. I am a fattass weighing in at an astounding 125lbs. If that helps any.
BTW nice pic of the Odometer on your site! Min just rolled over the sam number and I wish I had my camera to capture it lol!
Brad
The fast ramp rates of the XE-R lobe actually provide better vacum as compared to a cam of equal size on a slow ramp. This means your car will be fine. People run much bigger cams than this and still get off with no problems. The cam is 2 degrees bigger than the X2 FYI.
Originally Posted by ICONZ28
It is still secret. But i am having mine cam doctored and i will be glad to tell only g5x3 owners. It's pathetic i have to cam doctor the thing just to know what i am putting in my motor.
