ABS light
ABS light
My abs inop light wont go out ever since I got dynoed today. I was wondering if I needed to unplug something and plug it back in or is it just going to stay like that. My abs works I checked it out on the way home. Any ideas?
check the wiring harnesses to the front wheels. I had one get cut and it gave me the inop light. The brakes still worked. I had to connect them back together and the light went out.
PMH
PMH
How long have u drove it since ur had it dynoed? It should go off after about 15 mins of driving and a couple of hard brakings. It came one because ur back wheel was spinning and ur front wheel didnt. It should go off soon.
Well it was about a 45 min drive home from the dyno shop. As for #'s I ended up with 330RWHP and 341RWTQ. I will check for the connection to make sure that did not come apart.
usually happens to me whenever I dyno my TA, but after a few mins of driving or even turning the car off and on again it will clear If not, crawl under their and check your ABS connections
