what head gasket do i use for 5.3 heads
Old 07-01-2004, 03:34 PM
sr_ryan1's Avatar
Default what head gasket do i use for 5.3 heads
does any one know the GM part number for the head gasket for the LS1 type 5.3 heads
thanks
Ryan
Old 07-01-2004, 04:17 PM
ktmrider's Avatar
Try "www.gmpartsdirect.com". I found 3 different part #'s depending on what year your heads were made.
Old 07-02-2004, 07:49 AM
sr_ryan1's Avatar
yes i found 2 part number on there site but im not sure what year the heads where made, i will look for the casting number tomorow
Old 07-02-2004, 10:19 AM
94form2000z's Avatar
I got my gasket set from Thunder Racing back when I did the install. Forget who helped me but she was very helpful and knew what I needed.
Old 07-02-2004, 06:35 PM
bigdsz's Avatar
I just got a set of AS 5.3's. The way I understood it from Jay was to use the OEM gaskets. The part # I have is 12498543 for 97-01 LS1/LS6. What nos are you showing?
Old 07-04-2004, 09:46 PM
bigdsz's Avatar
ttttt
Old 07-04-2004, 10:15 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Use the gaskets specified for your engine displacement, use OEM 5.7 for 5.7 blocks, use 5.3 gaskets on a 5.3 blocks. If you use a gasket that has a smaller bore than your piston, you will have engine noise as the piston will make contact with the new gasket.
Old 07-05-2004, 06:27 AM
sr_ryan1's Avatar
casting number is 706, using these heads on a 98 LS1 block, these blocks bores are smaller than the 99 + arent they?
Quick Reply: what head gasket do i use for 5.3 heads
