Re-Use felpro head gaskets
I had a lifter fail about 3 weeks ago. I replaced them and used the fel-pro head gaskets. I had another lifter fail 2 days ago. I pulled the heads, and the gaskets appear to be in great shape still. Can I reuse these? Nobody in the area has the head gaskets!
I will most definately use new head bolts.
Absolutely not...Especially the grahpite composite.
Go to summit and switch to the Gm MLS, ask for saturday delivery..
Less that $30 a pair!
The also have the bolts
yould be crazy to REUSE head gaskets that is the most important gasket on the motor.and even if you could why risk all that work for only 70 bucks or so
