rounded arp head bolt...please help!!!!
This is crap.... Its the most rear passenger side bolt, pain in the *** to get to. Anyhow, these garbage, crappy, POS... felpro head gaskets started leaking again (2nd one that leaked), so while i was on the 2nd to last bolt it rounded. I have all other bolts off on both heads and have been using a little mirror to see it. Well, I did the most logical next step and went to sears to buy a kit to grip rounded bolts. That didn't work either. I need a way to get that bolt out without buying a picker and taking my hood off.... I can go out and buy one but absolutly want to avoid it at all costs... It seems that there is too much pressure on that bolt...so i put the whole head back on and still nothing...also tried hammering on a 1/2 inch socket...still rounded.... any advice????
i did the same thing man. only mine was the very back middle one. i finally had to barrow some of those sockets that have twisted teeth in them. it came right out. i dont remember exactly what they are called. but, they work.
anyways, best of luck. cause i know how fast it can make a guy throw things.lol
later, nick.
later, nick.
I'd say stripped bolts are the cause of about 80% of the frustration of working on our cars. I feel your pain bro.
Good luck getting it straightened out. I've also heard of using a "crows foot" to remove stripped bolts like this ? Never seen one in action but they're supposed to work really well...
Bad30th
Bad30th
Originally Posted by Dope
Just put some vice grips on it and back it out.
Dope
Dope
Originally Posted by Reckless
Do you have access to a welder? Worse case you could weld a socket to the head of the bolt. Or weld an extension to the head of it and use a breaker bar.
The sockets you talk of are called Turbo sockets, the only problem with those is that when you put pressure on them to turn a bolt they want to kinda twist off one side. if you can hammer it down on the bolt really good it may work.
Originally Posted by strokedls1
Vice grips on 65lbft head bolt will not work. Welding a socket on or those twisted teeth socket are your best bet.
Just an alternative. I don't have a welder, and I don't know if he does either.
Dope
Here is the thing...i used my torque wrench to try and break the bolt loose. It was torqued at 85lbs...the wrench broke that ft/lb....so that bolt is barried in there....don't know what the hell to do!!! I'm going to try either to grind it down or pull the motor...thanks for your help guys....late
