Another question on cam install.
Re: Another question on cam install.
Drilling the hole larger in the throttle body blade is not a substitute for getting programming. With a TR224, I would highly recommend getting programming to help with low RPM problems. Then if you want to smoothen out your idle a little bit, you attempt to drill the hole larger. There is no standardized hole size that you need to go with for any cam. To me, its just a band-aid.
