Is there a direct fit 1.4 or 1.5 ratio rocker arm for the LS1?
6600 rpm clutch dump of death Administrator
Originally Posted by 94form2000z
Umm doesn't ratio effect lift not duration? Maybe that's what you meant.
When you go to a 1.4 ratio your cam now has to have a lobe lift of 0.03571 to get to .050 at the valve. That addition lift means less duration @ .050
With 1.4 your duration that you had with a 1.7 is now really your duration now @ .041. For instance, on a stock Z06 cam going to a 1.85 nets you about + 2 degrees of duration. I would expect about the same drop going down in ratio.
seat to seat, yes they will open and close at the same time, I agree with J-rod with higher ratio RRs you achieve .050 early in the cam lobe and it ends later, thus increasing duration @ .050 they will not increase overall duration though, so high lift rockers increase the ramp of a cam lobe.
1 Post
Makes no sense how changing rockers changes the amount of time a lifter is on a cam lobe Which is what determines when the valve opens how long and what lift. All you changed from what I'm understanding is the amount of lift after fulcrum on rocker
True, but since all that is spec'd is the cam lift & duration, that's what everyone calculates the rocker arm ratios back to. You don't see people stating how far the valves will open or for how long or how quickly they transition.....
There is actual lift and duration. Then there is effective lift and duration.
By changing a rocker arm ratio you don't change the lobe, but for instance if you go with less rocker arm ratio it take more actual "time" to open the valve to .050 so the observed duration is less than it was with the larger rocker.
Conversely if you put a bigger ratio rocker arm, the cam lobe doesn't get any bigger physically. But, you get to .050 lift "quicker". Thus the effective duration is bigger. If you want an actual number I have two campros comparing a Z06 cam with a 1.7 vs a 1.85. Effective duration went up around 2 degrees.
Yeah, I can see that. Duration @.050 would be down. The duration overall would be the same, it would just appear to have a teensy bit less duration @.050 because the ramp would be lower.
