Got my Jantzer Ported TB........PICS
Old 07-28-2004, 05:34 PM
Ferocity02's Avatar
Default Got my Jantzer Ported TB........PICS
Just got this thing in the mail today. A little bit of a wait (5 weeks), but it got here! It looks AWESOME, to say the least. I went with the chrome smoke color, and it tunred out really nice. The spring and the cylinder thing have been polished. The shaft where the cable sits has been powdercoated black. It looks like the bump stop has been ground down some. Can't wait to get it on the car! Here are some shitty pics...
Look at the throttle blade closely
Old 07-28-2004, 05:42 PM
CanuckSS's Avatar
Looks like a nice piece!
What kind of gains does Jantzer claim?
Old 07-28-2004, 05:45 PM
Ferocity02's Avatar
I am not sure. I'm hoping for a good 5-10 rwhp, somewhere in there.
Old 07-28-2004, 05:54 PM
Quickin's Avatar
He does some damn nice work. I have to send him my calipers, TB and valve covers.
Old 07-28-2004, 08:08 PM
Ferocity02's Avatar
Just got back from a test ride. I noticed a definite increase in power and throttle response. The blade makes a squeaking noise when opening and closing from the blade rubbing on the inside of the TB. Hopefully it will go away over time. I also now have some idle problems. The car holds at about 1100 RPM and doesnt drop until the car is stopped. It takes awhile to drop too, maybe 5-7 seconds to get back down to 700 RPM. I lowered the idle screw all the way. The hole in the plate is the same size as the one in the stock one. Not sure whats going on. Anyone have any ideas?
The install took about 15 minutes. Taking the stock TB out was cake. I even did some PCV work while I had it off. I torqued the bolts to 8.5 ft-lbs.
Old 07-28-2004, 08:13 PM
Administrator
unit213's Avatar
Put some miles on the car. Let the computer learn. See if that helps.
Great looking TB!
Old 07-28-2004, 08:23 PM
Fastt Gunn's Avatar
Dude.... I got one and had the same problem. It sticks on opening and won't close all the way without me blipping the throttle. I was going down the road at 35 MPH with my foot off the gas. It was on my car for all of 10 minutes before I took it off and am sending it back for a refund. Im sticking with my Thunder Racing one which works perfectly. I was just looking for a little touch of bling. This after a long wait and hearing from so many others who recommended it.
good luck
Old 07-28-2004, 08:35 PM
JamRWS6's Avatar
good luck
tell him your problem and I'm sure he would be glad to fix it for you.....Scott is a great guy to deal with.....oh and his TBs are pretty nice too.
Old 07-28-2004, 09:09 PM
Senior Member
Country Boy's Avatar
Its because of the filled in IAC holes. The computer may learn it out.
Old 07-28-2004, 10:30 PM
Quickin's Avatar
ferocity,
Why don't you do an idle relearn?
Old 07-28-2004, 10:37 PM
dand35th's Avatar
try to unplug the tps sensor, then turn key on, for 10 secs.. then turn off and replug sensor in.. sometimes works..
Old 07-28-2004, 11:25 PM
Ferocity02's Avatar
Originally Posted by Quickin
ferocity,
WTF is that?
Old 07-29-2004, 02:35 AM
LS1LT1's Avatar
Question
Is the little hole in the blade mandatory?
And what are the differences in years? '98 the same as '99 and then '00-'02 the same as well?
Is it just the cam lever size that's different and which years had the bigger one?
Old 07-29-2004, 03:11 AM
jrp
SN95 Director
jrp's Avatar
The '98-'99 F-body throttle bodies have a smaller cam compared to the '00-'02 F-body TB's
- The smaller radius throttle cam opens the throttle plate faster
Old 07-29-2004, 03:17 AM
LS1LT1's Avatar
Question
Ok thanks.
What about the hole in the blade, can a car idle/run/go fast without it?
Old 07-29-2004, 08:02 AM
Senior Member
Ok thanks.
I dont have the idle air hole in my throttle blade
Old 07-29-2004, 11:16 AM
Ferocity02's Avatar
What should I use to fill in the hole in the TB?
Old 07-29-2004, 12:11 PM
01 Red WS6's Avatar
When I put my TB on it did the same thing, just put some miles on the car and it will go away. It takes some time for the computer to learn.
