Header Gasket Suggestions?
My old header gaskets for my flowtechs are now pretty much useless... So does anyone have any suggestions for some good gaskets that wont leak?
Thanks alot.
Bryan
Thanks alot.
Bryan
Thanks alot.
Bryan
Thanks alot.
Bryan
Originally Posted by Tranzor_Z28
I just bought a new set of OEM style metal gaskets from Napa... work just fine, no leaks.
I'm changing headers and going with new OEM GM metal gaskets. My first set of headers, I used the paper gaskets which shipped with my JBA headers and they worked fine, but, if you don't re-torque them after they heat up, you'll stand a good chance of blowing a chunk out of the gasket. Go with the metal gaskets and torque the bolts down evenly in the correct sequence. Even with the metal gaskets, it wouldn't hurt to re-torque them after you've driven for a couple of hundred miles ... simply because heat effects any material ... irregardless of how temperature tolerant the material might be.
I just went to my Pontiac dealership today and ordered the gaskets. They were $16.63 each and a bag of 10 OEM header bolts was $11.90. Total with tax was $48.33 for both gaskets and the 10 bolts. Straight off the Parts Invoice, the Gaskets are part# 12558573 and the bolts were part# 11515758.
