How big of a difference is a solid cam on a LS1
Old 07-31-2004, 11:50 PM
taqwache's Avatar
Default How big of a difference is a solid cam on a LS1
i was just wondering how much HP can a soild cam gain on a LS1 motor. when i used run my old SBC, i remember that when i put in my first solid cam i lost like half a second in ET . considering that LS1s have ramp acceleration rates close to BBCs, i would figure that the only gain would be the fact that you could get a bigger cam then what is normaly offered by hydrolic grinds.
anyone?
Old 08-01-2004, 12:53 AM
Boostaholic's Avatar
I thought the main advantages to a solid roller setup were a more solid valvetrain at higher rpm, and more aggressive ramp rate cams, which would mean more flow but I don't think thats the main issue?
Old 08-01-2004, 02:45 PM
taqwache's Avatar
also you dont have to worry about preload but the main thing i was wondering was mainly a HP gain or ET lost on average.
Old 08-01-2004, 10:52 PM
FASTONE's Avatar
I think the main advantage would be higher rpm due to stiffer valvesprings without colllapsing the lifter, also ability to go more radical on duration and lift.
