ATF Fluid?
ATF Fluid?
What is the best AT fluid for an A-4. I will be installing a TCI SSF3500, Trans-cooler, and deep pan shortly. Would like some opinions on which Trans fluid you guys use. Thanks
I was always told to use a non-synthetic formula for our trannies equipped with converters......reason being it has less slippage.
I assume this is still the general consensus...maybe more people will chime in
I'm using and I recommend Neo Synthetic ATF fluid.It meets the Dextron III specs, so it's safe. It will cost you $$$, but it works!!! It's $39.95 gal, or you can get 5 gals for $188.
Here's where you get it:
http://www.bakerprecision.com/neocirc.htm
Any Dextron III is good, and royal purple is WAY OVER RATED! Dont spend 5 bucks a qt for that ****. We use good ole Pronto ATF, works in the best trannies we got, car doing low 11s & low 10s with stage 3 trans and even our special stage 3 1/2. Getting excited here in the next couple weeks, were stripping my car down and doing a little weight loss program and taking aim at Pabones old title. But Im staying with the 4L60E bc I love my OD! Neways, just regular tranny fluid works fine, if it gets hot, just flush it and put some fresh stuff in to protect the viscosity. If you really need the pay for the high dollar stuff, it wont hurt, just make sure its the DEXTRON III type fluid.
