Cam for Big Cubes. How do I scale up from a 346?
Old 08-07-2004, 04:30 PM
Ragtop 99's Avatar
Default Cam for Big Cubes. How do I scale up from a 346?
I've had a number of cams in my 346 and know how they feel and what their drivibality is. As I look to bigger cubes, how do I scale up to acheive the same relative drivability / performance trade off?
For example, in a 346, the 224/224 has become a benchmark cam. Decent power and near stock manners with simple tuning. what would be the equivalent cam for a 383 stroker, Iron 408, or 422?
Old 08-07-2004, 04:34 PM
CHRISPY's Avatar
depends on the lobe type and exactly what you are looking for.
A 232/232 on 114 in a 385 will behave similar to a 224/224 112 in stock cubes.
My 236/240 110LSA cam is surprisingly mild
Old 08-07-2004, 06:45 PM
MUSTANGEATER's Avatar
You would want to take your combo as a whole then decide what camshaft. I'd factor in Intake, Heads, CID, the Bore and Stroker (which one is larger or is it square), the compression, the quench height, all that.
If you have 2 motors the same CID but one has a higher compression ratio. The one with the higher compression ratio would be able to tolerate a larger camshaft and still remain streetable.
Old 08-07-2004, 08:32 PM
Ragtop 99's Avatar
Assume, the compression ratio is in the 10.8 - 11.2 range.
the 383 and 408 are both pretty close to square. A 422 would be slightly larger bore than stroke, but the bore/stroke ratio is less than a stock 346.
Old 08-07-2004, 08:48 PM
Ben R's Avatar
Cam size and Engine size do not grow linearly (Is that a word?).
There are way too many variables that lead to camshaft choice for that to be possible. If you're looking for a cam matched for your application, you need to hire th expertise of a well-known camshaft grinder (I.E. Ed Curtis/Erik Koenig, not Comp/Lunati).
Old 08-07-2004, 08:49 PM
Why such of a low compression ratio??? You'd be looking at something w/ mid to upper 230's on the duration on the exhaust side and upper 230's to lower 240's on the duration. This is just a guess, w/o knowing all the info. Personally I'd aim for more compression than 10.8-11.2 even if you're on 93 octane.
Old 08-07-2004, 08:51 PM
Werd I agree. Someone who knows what they are doing makes running 12.5:1 compression on 93 octane possible also.
Old 08-08-2004, 08:36 AM
Ragtop 99's Avatar
I hadn't thought about going over 11.5:1. Does the fact that its 408 make it easier to run more compression than a 346?
I was thinking along the lines you appear to be suggesting; maybe a 236/232 for a 383 or 240/236 for a 408.
Old 08-08-2004, 08:45 AM
Ragtop 99's Avatar
I would agree that appears to be non-linear. I see 422 motors with a 250 ish intake cam compared with a 230 cam on a 346. The growth exponent is less than 1 (e.g. a 20% increase in cubes requires less than a 20% increase in intake duration.)
Old 08-08-2004, 10:17 AM
FASTONE's Avatar
I believe a good rule of thumb is 6 to 8 degrees for every 50 ci.So if you go to a 408 you could use a 230 or 232 cam and be close to the 224 in a 346.You may go 236 and be OK,remember that a longer stroke say 4" changes your rod to stroke ratio and increases piston acceleration so a tighter lobe separation should work better.Go with as much lift as you can.
Old 08-08-2004, 03:20 PM
Visceral's Avatar
My 230/228 114 in a 387 felt exactly to me like the 221/221 114 that i hade in it before with the 346. Im moving to a 236-236 114 (mti Z1) assuming that the idle will roughly resemble my 224/224 112 in the 346.
The 230/228 114 peaked at a low 5800 rpm in the 387 all bore. These larger CI engines take alot more cam than I expected. If I was going to 427, (which I still plan on someday when Im comfortable with my resleeve) I would think a 242/242 114 would be surprisingly mild. Thats 20 degrees more than the original 221 or 222 that my MTI C1 was and should idle/peak somewhere similarly..
Old 08-08-2004, 06:53 PM
Well the larger bore 4.030 vs 3.90X does help, but you can get away w/ more than 11.5:1 on a 3.90X w/o a problem. I wouldn't be surprised if someone could get away w/ 13.0:1 compression on a 4.125 + bore on 93 octane.
You can't just hodge podge it together. So make sure all your parts are matched together correctly and the camshaft is selected by someone who knows wtf he's doing and not the average internet guru.
I think in a higer compression motor you'll find a 240/236 will be a lil bit smaller than you would want to go towards.
Old 08-09-2004, 01:00 PM
Ben R's Avatar
Bore size and static compression ratio don't increase linearly either. Just because you magically get a bigger bore doesn't mean you can throw more compression at the motor and expect to get away with it.
Part of what you said is true though. You can run a static compression ratio of 13:1 and still have a 93 Octane motor. You'll just need to pick a camshaft that will lower the dynamic compression ratio.
If you're looking for a good, reliable stroker motor that isn't 'max-effort' but does hold it's own, a static compression ratio of about 11.5:1 is typically a good ballpark figure.
As you're probably beginning to see, all of this can get pretty complicated. That's why it's sometimes best to pay true professionals to put together a motor for you based on your goals and budget.
Old 08-09-2004, 02:48 PM
STF Veteran
99-LS1-SS's Avatar
This is my head
This is my head after reading and trying to understand all of these posts
Old 08-09-2004, 03:03 PM
marc_w's Avatar
I was wondering about this myself, but I never got any hard answers.
If it helps, my TR220 on a 112 runs pretty good on a stock tune in a A4 6.0. I kind of wish I went bigger.
Old 08-09-2004, 11:41 PM
Well yea I wasn't saying all that, prolly came across that way there's a lot more to it.
Ding Ding Ding we have a winner.
