RWHP estimate with AFR 205's and TSP magic stick
What kind of rear wheel HP do you think this combo would produce? I think the cam specs are 237/242 with 610 lift on a 112 LSA. I have the usual bolt ons, LT's, lid, and SSRA.
Originally Posted by 99ssleeper
My guess is more than all but 2 fbodies in this area (Jakes and the guy with the turbo 30th Z)....
470-490rwhp NA?
LS1Tech Premium Sponsor
It's going to depend on how many of those "little" mods it has (i.e. intake manifold, electric water pump, etc.). It will make a LOT of power, but we'll find out for sure pretty soon.
Trevor
Texas Speed & Performance
Trevor
Trevor
OOPS! Posted under a buddies name.
Trevor
Trevor
I'll be the SSleeper then, huh Mike(99SSleeper)?
I'm hoping for 500rwhp with this set up.
Originally Posted by 11 Bravo
From reading past posts, I understand that anything bigger than a 228 cam will need to have the pistons flycut with the AFR heads. Just something to think about. Please correct me if I'm wrong.
You could run our 231/237 easily with a set of unshaved AFR 205 heads without having to fly-cut the pistons. As mentioned above, you can have four different cams, all having the same duration at .050", and have completely different clearances. LSA and the amount of advance ground into the cam will change it quite a bit, not to mention the aggressiveness of the lobes!
We have 10 sets of AFR 205 cylinder heads on order from our original first order. Six of the sets are pre-sold, so we currently have four more sets up for grabs. If they aren't all pre-sold, we might have to try a set out.
Trevor
Trevor
Some company on here pulled 481 with the 205s and a 224 cam...'nuff said!
Right.... With the amount of boltons that car has, I would say most any high flowing head and over sized cam would make the same power.
Trevor
Trevor
