Open headers and o2
LS1TECH Sponsor
The problem is the O2's are too close to the end. Unless you are at WOT, if you are in closed loop the outside air contaminates the O2 readings and your car will continue to add fuel until your LTrims are maxed out.
When I run open headers I force the car into 100% open loop.
