Drag Racing Tech
15x8 or 15x10's
Old 11-14-2002, 12:22 AM
98TAauto's Avatar
Default 15x8 or 15x10's
should i go with a 15x8 or 15x10 rim??
i just have a small cam, vig3600, and 3.23's
also i plan on keeping stock 10bolt for a while so would it be worth anything to go with a 10inch wheel??
im thinking about just running a 15x8 bogart with a 26/10.5/15 et street
Old 11-19-2002, 11:02 AM
fastlif's Avatar
Default Re: 15x8 or 15x10's
I just put 15x10 welds on my car. No increase in traction but sure looks alot better. I also have stock rear with heads/cam vig#7.
I had to grind the hell out of calipers BUT it looks 100 times better.
Old 11-19-2002, 11:55 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
This LS1 thing is so addicting that you need to just go with the 15x10's and be done with it. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Old 11-19-2002, 07:09 PM
justin sutton's Avatar
I just ordered a set of 15x10s.I am going to run 26x10x15 et drags.I have all stock suspension and rear except for a 373.I had 26x11.50x16 et street's and the best 60ft I ever cut was a 1.68 this sucked because I have a 3200 vig.It was still spinning.I tryed everything from 10 psi to 22psi.The ets would not hook my car for some reason.This is on motor.Mac's,true duals,xpipe,hpp3,lid,& short belt
